Horse power reader?
Old Jun 25, 2006 | 05:04 PM
Bane's Avatar
Horse power reader?
Is there anything short of a dyno machine that i can buy for relatively cheap to read the horsepower on my carbureted '86 305?
Old Jun 25, 2006 | 06:43 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
cheapest thing you can do is do a local search for a dyno around you. Thats pretty much the only way I believe you can assess the power of your engine is through a dyno. Im not sure but I believe its something usually around 75 dollars for 3 dyno runs.
Old Jun 25, 2006 | 07:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
This is what you want
Home Dyno
Old Jun 25, 2006 | 08:31 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
whoa, I never knew those existed.
kinda sounds like a scam though.
Old Jun 25, 2006 | 08:45 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
don't take any stickers off the car while it is on. that might cause it to read a lower hp level
Old Jun 25, 2006 | 11:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The principles are sound. I was fooling around with something similar a few years ago.
Old Jun 26, 2006 | 12:11 AM
fawien's Avatar
Seen these written up in pop sci, they gave a good review but i cant say if they work well.
Vehicle Performance Computers : JC Whitney, Car Parts and Accessories
Old Jun 26, 2006 | 11:21 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Yeah this is the first thing that came to mind. Personally, it is what I would go with, short of a Dyno.
Old Jun 26, 2006 | 02:19 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
If you can get to a track then the trap speeds should give you an idea of your hp.
-Schultzy
Old Jun 26, 2006 | 02:46 PM
Phatfiddler's Avatar
I wonder how they got the HP gauge to operate on the Veyron. I think i read somewhere that the only way to hook up a gauge is to use a buffer of some sort, that reads RPMS. You program the buffer based on your dyno sheet that you got a your local dyno shop. The gauge outputs your "HP" based on your RPM at that time.
Old Jun 26, 2006 | 02:49 PM
Well, I know on the Beltronic Performance Reader, they calculate the amount of G's being applied to a g-meter of some sort inside the device. How accurate can this be? I dont know, but if I have a little extra money lying around when I take the IROC to get dynoed, I'll purchase one and compare.
scottmoyer
Sep 5, 2015 09:33 AM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
