fuel filter on 85 carb
Old Jun 26, 2006 | 02:40 PM
85LT4Z28's Avatar
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
hey how do i get to the fuel filter on the 85 carb i just picked one up and am looking to install it and i dont see it is it in the tank or on one of the fuel lines please help want to get that changed out... and how dificult is it to install
Old Jun 26, 2006 | 03:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
it's in the front part of the carb.
you'll need a 5/8" flare wrench, to turn the nut on the line, and a 1" wrench to hold the nut in the carb still. Once you disconnect the line, loosen that 1" nut that you just held still. That'll puke 1/2 cup of gas, and your filter will fall out, with a spring. Put the new filter in, keeping track of the direction of the filter, (rubber thingie in the center), and the spring, and clearish white washer.
Old Jun 28, 2006 | 08:44 AM
85LT4Z28's Avatar
thanks i was looking everywhere but there...
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
