charging issues HELP!!!!
Old Jun 28, 2006 | 08:47 AM
nathanielehlert's Avatar
Car: 1986 Camaro Z28
Engine: 305 TPI i might be a 350
Axle/Gears: Stock
I just got an 86 z28 305 TPI when i got it all it need was a battery cable and paint well now i have changed the pos battery cable and the altenator which seemed like it was fixed then i drove it to work and on the way home it started to die and i shut off the headlight and it quit dying the battery is now dead and i have no clue what could be wrong any more help please
Old Jun 28, 2006 | 08:57 AM
spifman's Avatar
Car: 1986 Camaro RS
Engine: 305 V8
Transmission: 700r4 automatic
I had the same problem when I got my '86, turns out they put in a shoddy alarm system that kept draining the battery. Check under the dash for anything that looks like an alarm. Otherwise, just tear through it and look for something that could be draining the battery (i.e. an overhead console that is turned on but has a bad bulb).
TrevinE
Sep 14, 2015 03:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheExaminer
Sep 7, 2015 08:34 AM
Slush92RS
Sep 2, 2015 08:56 PM
