Does overheating a starter cause power lose in the starter?
Old Jun 27, 2006 | 08:38 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
If a starter is overheated does it die or just lose power? I can turn my newly built 383 strocker over without plugs in, but once I install the plugs it hardly moves. I have a Powermaster XS Torque Starter, which is rated to an 18 to 1 compersion ratio, I calculate 10 to 1. Have I Smoked the starter? It does this even after I let it sit for a day.
Old Jun 27, 2006 | 08:57 PM
TymeStopper's Avatar
Car: 2 Stangs, 2 Third Gens, AWD Talon
Engine: 302, 302, 305, was 327, 4G63
Transmission: T5, C4, T5, T5, 5 Speed
Axle/Gears: All Kinds.
I don't think you've fried the starter. Unless you've sat there and cranked it for like a minute straight. Sounds like you've got something else going on.....
Lowell
Old Jun 27, 2006 | 09:01 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes the starter has less cranking power when real hot.
copper gains electrical resistance as temp raises.
Sounds like the starter is either now toast or was defective to start with.
Good conections are important as is proper starter/ring gear alignment and gap. (shimming) You want to test it under load (cranking) measure the voltage drop.
( amount of voltage not going thru the starter) and amperage draw.
either, if exessive indicates a faulty starter.
The radiant heat off of headers really shortens the life of starter motors. A heat shield can help.
Old Jun 27, 2006 | 09:40 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
the only other thing I can think of is timing is off
Old Jun 28, 2006 | 10:12 AM
I was also thinking the samething. The timing might be off by a bit.
Lowell
formula_novice
Sep 5, 2015 03:58 AM
5spdcamaro
Aug 28, 2015 02:12 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
