Anyone ever had a performance chip be the cause of a failed inspection?
Old Jun 27, 2006 | 09:14 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Just curious...the NOx on my RS failed the state inspection today...MA allows a limit of 2.50 (I think grams/mile), and the car blew a 2.65 Both CO and HC were fine.
It said on the failure notice a variety of things that could lead to an NOx failure, including "advanced timing." The car has a Stage 2 Hypertech chip, but also hasn't been tuned in awhile, I think. I'm doing a full tune up, including the EGR and PCV valves, O2 sensor, everything...
Should I remove the chip as well for my re-inspection? I assume not, but wanted a second opinion. Thanks to anyone who can help...
Old Jun 27, 2006 | 10:06 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
he bees a righto daddio
wut most ov thos purformence chips du is advanc the timing alot mor then normul wen yu du that it will increse the tempuratur in the cumbustun chambur. higher cumbustun tempuratur is going to creat more nitros oxids.
that is wut the egr valv dus. puts the exhast into the combuston chambur since reletive to the burning air fule mixture it is alot culer
another thing I wanted to add most of those off the shelf "performance" chips are a waste of money. don'ot fix anything, don't make you faster, and can cause more harm then good.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Ranbo108
Sep 9, 2015 12:20 PM
Stryker412
Sep 7, 2015 09:11 AM
