HELP setting valves procedure!!!
Old Jun 27, 2006 | 09:45 PM
Ltrain925's Avatar
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
i have an L98 from a 89 vette with stock aluminum heads,stock roller lifters(not pushrods),a ZZ4 cam, and 1.5 roller rockers, i put this in my 85 T/A and i can't get the valves setting right what is the procedure to set them, i bought a hanes book tried it didn't work, called jegs tech, didn't work so im lost please help the car starts but misses the rockers are so sensetive. thankyou
Old Jun 27, 2006 | 09:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
do the EOIC method. Search on it. I know sofakingdom mentioned how to do it recently, like within 2 weeks or so.
Old Jun 27, 2006 | 10:13 PM
Ltrain925's Avatar
Car: 85 T/A
does that apply to my cam and rocker arms as well, im not sure if the camaro and firebird l98s came with rollers only pushrod, im not sure though.
Old Jun 27, 2006 | 10:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
all non overhead cam motors will be the same method.
Old Jun 28, 2006 | 12:20 AM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
One way to do it, you would have to mark the dampner 90 degrees, 180 degrees, and 270 degrees (it doesn't have to be perfectly marked). By starting with #1TDC you would adjust the cylinder that has just fired before it (#2) the intake valve, since the cylinder will be getting ready to open the exhaust valve. The cylinder after (#8) will have just had the intake valve open, so the exhaust valve would be adjusted. Zero lash is where the pushrod just stops moving up and down as you turn the nut, and then the additional turn. some people like a 1/4 turn, some half turn, some 1 whole turn. I like a half turn and see how it sounds.
here's the pattern:
#1TDC #2 INT #8 EXH
#8TDC #1 INT #4 EXH
#4TDC #8 INT #3 EXH
#3TDC #4 INT #6 EXH
#6TDC #3 INT #5 EXH
#5TDC #6 INT #7 EXH
#7TDC #5 INT #2 EXH
#2TDC #7 INT #1 EXH
specialized
Jun 18, 2022 09:26 AM
lakeffect2
Aug 23, 2015 08:44 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
