My new short block didn't cost an arm and a leg, but it almost cost me my finger....
Old Jun 23, 2006 | 11:47 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Well my short block came in yesterday, and I was very happy to see it So, I load it into the back of my truck (used the alignment rack at work to lift it into the bed) and took it home. So today, I called one of my friends over to help me unload it. This thing is heavy!!! Not that I had expected it to be light, but I guess that forged crank, rods, and pistons weigh a considerable amount more than cast/nodular iron/other non forged material. Anyway, the machine shop had bolted the short block to this metal engine cradle thing. So my friend and I load the engine out of the truck and onto the dolly. I start to pull the dolly off the driveway and into the sandy/grassy area on the side of the house so that I can put it in the shed. Anyway, the right wheel of the dolly sinks in the sand, and the dolly tips over. So does my engine I tried to grab it with my right hand to keep it from falling but it's just way too heavy (400 lbs). Needless to say, the block fell over and sandwiched my hand against the rim of my camaro. My index finger got messed up really good. The block sliced through all 7 layers of my skin, through the fatty tissue, and you can see my bone. My friend asked me if I was OK and when I showed him my finger he almost threw up/passed out But the good news is that there was no damage to the block!! Anyway, next thing on my list now is to get the AFR 195 heads and the COMP cams retro-fit hydraulic roller lifters. Then I'll be able to mock up the engine, find out what length pushrods I need, and finally check my valve to piston clearance.
Old Jun 24, 2006 | 01:56 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Damn dude! Rough stuff. Just when you get all happy...wham. Your fingers now messed up and your project is on the back burner. Post some pics haha.
Old Jun 24, 2006 | 02:05 AM
EvilCartman's Avatar
Car: '82 Z28
ouch!
Old Jun 24, 2006 | 12:13 PM
paulmoore's Avatar
I was gonna post a pic but figured it would have gotten deleted cause it wasn't *third gen related* even though the engine is going into my camaro. As of right now I have my finger wrapped up with some gauze/tape and loaded up with Neosporin I kept thinking to myself afterwards that i should have just let it fall. After all it was on a little crate thingy, and there wasn't any damage anyway. But the way I see it, anyone here would have done the same thing. Kinda like instead of WWJD(What Would Jesus Do) I was like WWAFTGOD(What Would A Fellow Third Gen Owner Do) Then the answer became quite obvious
Old Jun 26, 2006 | 01:29 PM
paulmoore's Avatar
Ok guys here is a pic of my finger. Now remember, this finger has been bandaged up for three days now with some butterflies to hold the gaping hole in my skin closed. So here it is....
Attached Thumbnails My new short block didn't cost an arm and a leg, but it almost cost me my finger....-finger.injury.jpg
Old Jun 26, 2006 | 01:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
... So you felt the need to show us a picture? Thank you for that... ugh, pardon me while I go speak with King Ralph on my great white porcelin telephone...
Good luck with the motor though, don't lie under the car while someone is lowering it into the bay!
Old Jun 26, 2006 | 01:59 PM
paulmoore's Avatar
Well, that's why I didn't post the finger pic the same day that it happened. I had fat tissue hanging out of the cut in my finger. I called my girlfriend at work and she came home for lunch to bandage me up. It is pretty bad when you have to push the fat back into the finger before you can try to bandage it up
Old Jun 26, 2006 | 02:18 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
ever heard of this place called a hospital?
Old Jun 26, 2006 | 11:56 PM
paulmoore's Avatar
Yes I have. I can tell you that I should have gotten stitches on the finger for sure. However, this happened about 45 minutes before I had to go to work and I am one of those guys who NEVER misses work for anything. I am glad, however, that it is healing on its own without any serious complications or infections....
Old Jun 27, 2006 | 12:18 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
sweet battle wound
Old Jun 27, 2006 | 12:24 AM
paulmoore's Avatar
Originally Posted by urbanhunter44
sweet battle wound
Honestly, my finger looks a whole lot worse in the pic than it really is. By the way, I like your avatar. A Clockwork Orange, correct? Gotta love Stanley Kubrick
Old Jun 27, 2006 | 10:27 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
can you still bend it? Are you sure you didnt cut a tendon?
I cut my finger like that, and I got nerve damage. The whole top of my left index finger is permanent pins and needles.
Old Jun 27, 2006 | 11:42 AM
paulmoore's Avatar
I can bent it slightly, but it is limited by the swelling. I don't think that my finger is broken, but it is possible that the bone is bruised. I have heard that you can bruise a bone with blunt truama. I can almost make a fist with the finger/hand, but I can feel the skin pulling and I don't want to reopen the wound. It has just started to close and a nice scab is starting to form. No nerve damage that I can tell, my girlfriend was poking my finger with a needle, and I could feel everything. Like I said before, I was very lucky. I'm a rather big guy, and I have thick hands/fingers. If that had happened to any one of my friends, it probably would have taken their finger right off.
Old Jun 27, 2006 | 05:58 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
go send a link for this to the "ever been injurued thread" lol then post a pic of a sushi roll to compare :P
Old Jun 27, 2006 | 11:45 PM
paulmoore's Avatar
I already posted the pic of my finger on that particular thread about 2 days ago. I remeber seeing that post and I was like hmmm... let's see what kind of injuries we have here. After I got through all of the post I was like, hell, I'm gonna post up my pic for S&G. Then I guess someone posted a pic of their finger hanging by just the tendon but the mod deleted it. I was like, How am I supposed to beat that???
Old Jun 28, 2006 | 12:39 AM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
OUCH
theshackle
Mar 5, 2017 06:37 PM
anesthes
Mar 10, 2016 10:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
