1991 z28 start problem
Old Jun 27, 2006 | 10:44 PM
gotay's Avatar
my 1991 z28 305 won't start went is hot.
I'm from up state new york
Old Jun 27, 2006 | 11:20 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
have you replaced the Ignition control Module yet?..I am assuming its losing spark?..if so by an AC DELCO replacement no junk from the local parts stores.If its not spark then shoot some more info out for us?
Old Jun 28, 2006 | 12:05 AM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Does it crank and not fire, or does it just click, or nothing at all, dash gauges/lights working, etc.. what does it actually do when the key is turned to the crank position???
Old Jun 28, 2006 | 09:08 PM
gotay's Avatar
yes is turned to crank. won't start went is hot normal temp
Old Jun 29, 2006 | 05:22 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Could be a number of things. First thing that I would check, and it's free, is open the computer and see if your running an aftermarket chip(piggy back). My car did the same thing except it would die after getting really hot and then would not start until it cooled. As soon as I removed that POS ADS powerchip my car ran like a champ.
After that, then I would suggest looking into other parts, like ignition modules, etc...
Old Jun 29, 2006 | 05:24 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LIGHT UP THEM SPARKLERS
OK because it cranks but doesn’t start you’re
not either getting spark or fuel. To check for spark
with stuff you probably already have: get a spare
spark plug, connect it to one of the plug wires,
connect the threads to ground, have a friend
crank the engine and see if you’re gettin’
your little lightin’ bolt.
Happy Racing !
- If people drove any slower
they’d be going backwards -
92camaroJoe
Jul 29, 2023 07:57 PM
jhawkeye
May 25, 2022 06:33 PM
Infested
May 22, 2018 11:56 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
