idle up and down
Old Jul 1, 2006 | 08:24 PM
gotay's Avatar
idle up and down
idle up and down after timing set to 6 in 1991 z28 camaro 305. heeeeeeeelp
Old Jul 1, 2006 | 08:30 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Make sure you unplug your electronic advance from your distributor when timing, and to plug it back in when you are done. It's a brown wire leading to a red plastic connection bung to the distributor.
You can also check your IAC motor to make sure it is operating properly. Check the tech articles, theres an article for testing and cleaning it out.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
