L98 heads
Old Jul 2, 2006 | 07:58 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
L98 heads
What size cam can i use with stock 350 l98 heads with nothing done ????????Please answer i can't find an aswer any where.
Old Jul 2, 2006 | 08:07 PM
Damon's Avatar
The main thing you want to look out for is lift. Anything up around .470" or more is likely to cause retainer-to-guide seal contact unless you machine the guides down or do other procedures to open up this clearance.
In other words, don't get a .465" lift cam and then put on 1.6 rockers. See what I mean?
Generally, this means a farily modest cam. Regardless, upgrading the valve springs is highly recommended even with a modest cam. For a mild street performance cam a set of Comp 981 springs is a big improvement over stock and they drop right in with no machining required whatsoever.
Old Jul 2, 2006 | 09:36 PM
JB22's Avatar
I put a ZZ4 cam in. but I had new springs to accomodate the lift and screw in studs and guideplates.
Just started it up today and it sounds mmm nice!
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
