lower intake gasket is leaking, a few questions
Old Jul 4, 2006 | 11:10 AM
Syn's Avatar
Syn
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
i noticed coolant on the ground the other day and pop the hood sure enough coolant is leaking form the lower intake.
my questions are, i've never mess with a distributer but i know i am gonna have to take it out to replace the gasket, now if i take it out will it only go back in one way? i don't wanna get the timing way off. other then that this looks like a simple job, take off the plenum,and unbolt the bolts take off the distrubter and the lower intake should come off, any tips or should i use RTV any where as well?
Old Jul 4, 2006 | 11:23 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Take off the dis cap, mark the position of the rotor with a piece of masking tape marked "rotor seated" put another piece of tape on the firewall behind the dissy and draw a mark on the tape and a matching mark on the dissy's base plate. when you pull the dissy up the rotor will turn alittle, mark this position with tape marked "rotor up", when you reassemble just line up the marks and you should be all set.
Old Jul 4, 2006 | 02:22 PM
Syn's Avatar
Syn
Engine: 305 tpi
haha sounds complicated, i'll give it a try
Old Jul 4, 2006 | 02:55 PM
it's easier than it sounds, you just have to know where everything is pointing before you take it apart.
Old Jul 4, 2006 | 10:10 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
i've never done that, i've gotten the hang of finding TDC as a result!
after you get it back together if you do that, at least put a timing light on it and make sure its 100% on the spot.
Old Jul 5, 2006 | 03:55 PM
Syn's Avatar
Syn
Engine: 305 tpi
great thanks its just i never took off a cap before so i'llhave to look up what each part is, only messed with DIS cars
i will be tearing into it for about a hour or so a day after work
so i'll keep this updated
Old Jul 9, 2006 | 02:20 PM
Syn's Avatar
Syn
Engine: 305 tpi
ok a little update and time for directions lol, the lim bolts where its leaking at were soo loose i could loosen them by hand WTF, how tight are they suppose to be?
i took some pics my camera had no battery so they came out crappy
in this pic gas has obviously been leaking i am thinking its the injector orings are bad, also i noticed the injector harness that comes out on the back they go staright out to the injectors, on the front they cross, if you understand what i am saying, is that normal?
Old Jul 9, 2006 | 02:28 PM
Syn's Avatar
Syn
Engine: 305 tpi
ok a little update and time for directions lol, the lim bolts where its leaking at were soo loose i could loosen them by hand WTF, how tight are they suppose to be? and so to take the dizzy off i take the two bolts off the side of the cap and can i leave all the wires connected on top ? then what do i do? i will take more pics when i take the cap off
any idea what these conectors are? they come out of the injector harness?
heres how it sits as of today
1992 Trans Am
May 10, 2023 07:19 PM
dutch930
Sep 11, 2015 06:58 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
