BBK Throttel body problem (TPS Sensor fit-ment)
Old Jul 9, 2006 | 12:13 AM
88GTAbandit's Avatar
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
I Bought a HSR and it came with a BBK 58mm TB, after swapping most of the parts, i get to the TPS and see that it is different from my stock piece...on my stocker it had a space between the TB side the and the sensor which was raised by molded spacing, and had an extension which activated the switch. now on the BBK its all smooth for a mounting surface, and there is no extension on the TB blades to activate the TPS like the stocker did....so i am stuck, please help...the car is a MAF 1988 GTA W/ 350 in it. as for the TB info, i am about to tear it apart to find any numbers for it...
thanx
dave
Old Jul 9, 2006 | 02:31 PM
I'm kinda starting to think it maybe an LT1 TB rather than the TPI...but am unsure if that would be it or not
mdtoren
Aug 23, 2015 12:52 PM
Navy8125
Aug 22, 2015 07:13 PM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
