Problems bolting up pan
Old Jul 7, 2006 | 06:04 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Well I had to beat the hell out of the new oil pan to make it go over the K-member and now that its on, when I go to raise it and bolt it up, you can only get one side to align and bolt up, and this makes the other side go too far from the lower deck to bolt it up. What can I do to get both sides fine and even as well as bolt up? Please help guys, this is really getting to me because I cant make it work. Thank you for any help guys.
Old Jul 7, 2006 | 06:07 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
you bent the hell out of the pan. Replace the pan, and make it fit in a gentler way?
Old Jul 7, 2006 | 07:21 PM
Replace the pan
Right... but most importantly, with one that actually fits. You've got a basically bone stock 170 HP car, you don't need anything exotic. Just get the right pan and call it a day.
Old Jul 7, 2006 | 08:16 PM
Engine: LB9, LB9
it is the right pan, its brand new with no miles, oe replacement milodon pan.
Old Jul 7, 2006 | 08:52 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Well,sounds like now it's a mangled one.Why,exactly,are you replacing it in the first place?
I've never done a pan in chassis,and I most likely wouldn't.IMO,you could have the engine out,swap the pan,and back in hooking stuff back up in the time it would take to fight with it on your back.
Old Jul 7, 2006 | 09:06 PM
Car: 89 formula 350
but its beat all to hell which is why it doesnt line up.
By another oil pan like it (or even a $30 stock oil pan from autozone like I did) and put it in, but leave the mallet in the toolbox.
Old Jul 7, 2006 | 09:09 PM
Engine: LB9, LB9
No way to fix it? Needs replaced because the old one rotted out.
Old Jul 7, 2006 | 09:27 PM
No; it's the other way around. It's beat up because it doesn't fit.
It doesn't fit, because it's the wrong one. There is no other explanation. The right one would fit; any pan that doesn't fit, is the wrong one, by the definiton of the word "wrong".
It may be "stock", but it obviously isn't "stock" for one of these cars. Just like your steering wheel or something; it might be "stock" for your car, but it isn't "stock" for a van, or a Caprice, or an Aveo.
Just go get the right pan for the car, and it will fit; put it on, and enjoy driving the car instead of working on it.
And this time, make sure the PVC is all hooked up and works right so that it keeps the moisture out of the oil, and keep the oil changed, so that the oil isn't all full of water, and then the new one won't rot out too.
Old Jul 7, 2006 | 10:26 PM
Car: 89 formula 350
you're sofakingsmart!
Old Jul 8, 2006 | 01:06 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
Old Jul 8, 2006 | 11:23 PM
Engine: LB9, LB9
Nope all oil has been taken care of since I got it, it was the last owners fault. I am so perfect with my car, that people cant even touch my dash while in the car or I will yell at them.
Old Jul 9, 2006 | 09:55 AM
Car: 89 formula 350
sounds more **** Retentive than "Perfect" lol
Old Jul 9, 2006 | 10:31 AM
Engine: LB9, LB9
yes I am, but you have to be, why do you think most third gens you see are ragged out?
Old Jul 9, 2006 | 05:11 PM
Car: 89 formula 350
I agree. I get compliments on my car all the time. Probably because most of them around here have at least one body panel in primer, and the rest of the car is dull lol
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
Amillionoh7
Aug 7, 2015 01:24 PM
