idle problem went engine is hot
Old Jul 6, 2006 | 12:09 AM
gotay's Avatar
my 1991 z28 camaro 305 went is cold idle ok went is hot idle is bad up and down sound like is running in 6-cylinder
Old Jul 6, 2006 | 12:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what?
Is english your second language by chance?
can you give more info? Did it just start out of the blue, or did you chance something first? What motor? The TPI or TBI motor?
Old Jul 6, 2006 | 11:08 PM
gotay's Avatar
idle problem went the egine hot (out of the blue)
yes start out of the blue . the problem start went the motor is hot idle up and down, sometime the motor won't start.( no computer code I jumper A and B I have only code 12). went is cold the idle is ok ( motor is 305 tpi )
thanx for you help
Old Jul 7, 2006 | 12:00 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
I think a good start would be to look into a pick-up coil or/and a ignition module and ignition coil.Something doesnt like the heat
Old Jul 7, 2006 | 07:19 AM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Replace both MAF relays
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
