91 camaro with something wrong
Old Jul 7, 2006 | 02:42 PM
TransAm90GTA's Avatar
Car: 1990 Trans Am Gta
Engine: 350 5.7
I was looking at a 91 z28 with a 305. it has about 165000 on it with a clean body but when i start it the engine rattles like a knock but then idles fine. If i pull the throttle and it startes to rev there is puffs of white smoke coming from next to the valve covers under the intake manifold tubes on the left back side looking at the car but it only happens when it reved and i took it for a test and it has little power. what i did should have spun the back but it just had no power and the tach says its up past 7000 rpms but its not. can anyone help at all by letting me know what might be wrong or how much it might cost to fix thanks
Old Jul 7, 2006 | 06:13 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
white smoke indicates coolants burning.
most probably its a sign that ur headgasket is either leaking or blown.
u can try engine treatment stuff or thicker oil and
that might seal up the leak for a while.
good luck.. head gasket is very expensive repair.
Old Jul 7, 2006 | 06:15 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
thicker oil wont stop a head gasket leak lol
Old Jul 7, 2006 | 06:29 PM
wezeles's Avatar
Car: 1982 Pontiac Trans Am
Engine: 383 stroker 4 bolt roller, juiced
Transmission: b&M th400
Axle/Gears: 4.10 with c-clip elims
good old bars leak... run it through see what it does... but the permanet fix is to replace your coolant system gaskets... water pump intake and head gaskets... i dont know with that many miles though i would just use bars leak and see if it holds... always worked for me
Old Jul 7, 2006 | 09:35 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
the knock could be a number of things, if it's coming from in front or rear of engine most likely a worn main bearing. you can pull off the oil pan and take a look, but I don't know if you want to.
Were the injectors ever changed? sounds like you have a manifold leak, but hard to say without looking at it.
evilstuie
Jan 9, 2020 08:29 PM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
Cripley
Aug 17, 2015 03:35 PM
dhonda200
Aug 11, 2015 11:50 PM
sonu1975
Aug 11, 2015 08:38 AM
