Where to set my timing???
Old Jul 7, 2006 | 07:12 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
I got a 350 mostly stock engine
Cam is 465 intake 488 exhust
Duration is 224 / 234 @.05"
I got a Demon 650 D.P. on top of a mostly stock intake...is raised a bit
I was just wonder what I should set my timing at
Thanks in Advance.
Old Jul 8, 2006 | 03:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Hold the throttle open to 3000RPM or so, and turn the distributor to 36* timing. Go back to idle, and reset your idle speed. Check the timing, probably around 16* or so. Leave vacuum advance on ported. Should work well.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
