How to reach dist hold down bolt?!!!
Old Jul 9, 2006 | 08:04 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Just got my 350tpi installed. Been running slightly off. Checked timing and I'm at 14 degrees. Trying to adjust the distributor to get the timing correct, but the hold down bolt seems like a b*tch to get to. Removed my spark plug wires and the cap, still cant seem to reach it. Am I doing this the right way?
Old Jul 9, 2006 | 08:10 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
haah i had the same problem today. i just got a 9/16 swivel socket and put it on a liek 2 ft extension and it broke loose for me.
Old Jul 9, 2006 | 08:13 PM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
There is a special wrench that makes it easier. It's shaped like a half square and has a 9/16 head on it. You can probably get it from a parts store. I have one that my father in law gave me.
Old Jul 9, 2006 | 08:14 PM
j dezzy's Avatar
Car: 87 TA
get a distributor bolt wrench. long handeled thing with a bend in it to tuck under the ditributor.
Old Jul 9, 2006 | 08:44 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Yep, special wrench.
It can also be done with a very short wrench.
Old Jul 9, 2006 | 08:51 PM
CrazyHawaiian's Avatar
Car: too many ...
I took a regular open end wrench, used 2 vice grips and had a friend hold a propane torch, heat it up and bent it and made it a special wrench. Works great.
Old Jul 9, 2006 | 08:55 PM
j dezzy's Avatar
Car: 87 TA
that's a good idea
Old Jul 9, 2006 | 08:58 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I use a 8" extension and a crows foot- basically an open end wrench head with a 3/8" square so the extension can be inserted.
SD
Old Jul 9, 2006 | 11:09 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Yeah, A-Zone carries them. Find the old one guy in there that will know what you're talking about. Simply called a dizzy wrench. Has a receptacle for a 3/8 ratchet to drive it. You don't use the ratchet much, just as leverage to rotate the hold-down bolt.
If remote mount coil, loosen the small vacuum manifold attached to the coil mount and push it aside for clearance. Cap and wires can stay in place, which is a good thing when adjusting timing. Double check the timing after tightening down the hold-down.
Old Jul 9, 2006 | 11:13 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
You should be able to find them in the tool section at AutoZone, and they are not expensive.
Old Jul 10, 2006 | 05:06 PM
thanks..i just stepped up and bought a set of crow feet. The 9/16 with and extension worked perfectly.
Old Nov 29, 2006 | 03:43 PM
87transamTtop's Avatar
Car: 1987 Trans Am
Engine: LG4 (I desire a 383)
Axle/Gears: Stock?? 1.0? :)
Best for LG4
Even with the "distributor wrench" or whatever you want to call it, I couldn't loosen the hold down bolt on my LG4. I could get to it but the intake was in the way and so was this unknown bracket.
My dad said to get one of those swivel head wrenches as mentioned above. Just used it today and it works like a charm. I recommend that over the distributor wrench. just my opinion
Old Nov 29, 2006 | 05:25 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Not all distributor wrenches (or distributors) are created equal. I learned this the hard way. I was in a hurry to do some work on my wife's distributor and had her pick me up a distributor wrench on the way home from work one day. It was the AutoZone special and wasn't quite the right shape. I went and bought a nicer set from Sears and they were better. However the AutoZone one did work on my old Blazer, so there ya go. I'd always prefer to have the correct tool.
Old Nov 29, 2006 | 07:16 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Na na, I have the endall of all ways to get to that bolt. I have been through countless attempts at that bolt with the L shaped distributor wrench, that thing doesnt do crap. You can also sit there with a short 9/16 wrench, but it takes forever.
Heres what you have to do. Get a 1/8" ratchet (the small one) and a short 9/16 socket. Get in between the firewall and the motor and bring the wrench in from the back, and get the handle in the area between the distributor cap and the coil. You should have around 3-4" to swing that thing. Few turns of the wrist and the bolt is loose enough to release tension on the hold down clamp. You can literally get that bolt loose, turn the distributor and tighten it in a matter of 30 seconds.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Linson
Nov 12, 2015 08:09 PM
mddaniel
Sep 8, 2015 05:16 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
johanlindgren
Aug 16, 2015 12:16 AM
