belt pronlem
Old Jul 12, 2006 | 12:20 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
belt pronlem
does anybody know the way to put the powersteering and alt belts on? i tried and the powersteering had come up short...... pics would help. thanks bill
Old Jul 12, 2006 | 02:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Are you able to pivot both the alt and power steering pump? If not, loosen the bolts/nuts so you can pivot them, get the belt on, then pull it tight and tighen the bolts.
Unless that's obvious to you, then it's 'cuz you're using the wrong belts or something.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
