1 piece rear-main 400?
Old Jul 15, 2006 | 06:38 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
I seem to remember a guy telling me GM made some 1 piece rear main seal, hydraulic roller 400s for Suburbans. Does anyone know if this is right?
If not, what does it take to convert a 400 to run in a manual trans f-body with a hydraulic roller cam?
Thanks,
Sean
Old Jul 15, 2006 | 12:35 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
All GM 400's are the old 2 piece rear main seal type. All used flat tappet cams.
You'd need a 400 externally balanced manual trans flywheel. and a "retro fit" hyd roller cam kit. Modify the timing cover (re-inforce for cam button stop) and use a cam button.
You'll need a oil pan from say a 1969 chevelle 350. Old truck pans will not fit the thirdgen cars.
Old Jul 15, 2006 | 01:36 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
you can use a pan from a 2pc 305 or 350 also like the ones in the older camaros, as for flywheel, you can use any neutral balanced flywheel (thirdgen flywheel) 2pc seal of course with a balancer plate that is sold by summit
retrofit roller cam, lifters, cam button and thrust plate, or a reinforced timing cover an dyour ready to go
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
