spark plug ceramic in cylinder
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I was changing my plugs and the third one back on the passenger side is really hard to get at. I usually end up breaking it off when trying to get the socket on it, no big deal, I just take the bottom part out at that point since I have a new one to go in anyway. This time the ceramic that is around the electrode broke, I guess when it broke on the outside the shock traveled down the plug and caused it to break. After I got the new plugs in I started the car hoping it would break up and blow out of the exhaust. Now it seems like it is missing and backfires out of that side while idling once about every 10 seconds or so. What have I done ?
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Sounds like a plug wire issue. Maybe the wrong firing order? I'd re-check and get a timing light. Check each plug wire and watch the strobe to find the miss.
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I had the first two wires on that side crossed, man that scared me !! Just took it for a ride and it is running great, and no backfiring !
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
