Bosch oil filter
Old Jul 17, 2006 | 12:12 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Bosch oil filter
First off I never used to have problems with my oil pressure until a little while ago, it was dropping very low under 15, and into the red so I replaced the oil pressure switch at first it seemed like it worked, but now pressure is dropping low again, and I got to thinking the other day, and reliezed the last 2 times I changed my oil filter I used a Bosch brand oil filter, and Im wondering if that could be the problem maybe its not flowing oil through it properly? Has anyone else tried one of these, and had a problem with them? Any help would be great thanks
Old Jul 17, 2006 | 04:58 AM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
This would be interesting to know the answer, because I'm having the same problem, and am about to change the oil pressure switch. I don't remember what brand I have, I think it's the same I've always used, but I'll check to see if it's different. And bump for a good answer...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
