Completly Polished Motor...Inside and Out
Old Jul 17, 2006 | 11:28 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I want to know if this is possible or has it ever been done before? Completly polishing an engine and head and intake. Inside and out, lifter valley, underside of motor, etc etc. This would not only look stunning but would promote amazing oil drain back.
What are any benefits or downfalls of this as well?
Old Jul 17, 2006 | 11:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It wouldn't look so hot when it started to rust.
Old Jul 17, 2006 | 11:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Theres clear engine enamel out there... and I can't see the lifter valley having corrosion issues
Old Jul 17, 2006 | 11:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok then, it wouldn't look so hot when the clear started to yellow, peel and flake, and then it started to rust.
If you wanted a shiny block, you'd be better off ceramic coating it or plating it or something.
Old Jul 17, 2006 | 11:45 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
There would be no clear coat. Just polished metal.
I'm talking hypothetical mostly, and also wondering if there is a car out there with this done. Pics maybe?
Old Jul 18, 2006 | 07:49 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Here's a link from another site, where this guy polished his entire 400 block. Check it out
Block Prep 101 - CamaroZ28.Com Message Board
Ok I think that worked this time.
Old Jul 18, 2006 | 10:14 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
...wow
Old Jul 18, 2006 | 10:51 AM
That guy CLEARLY had too much time on his hands.
Seems that you could ceramic-coat the block after that, with the shiny silver coating I suppose, to preserve the polish.... that would be kind of cool actually, a shiny silver block. It would also last a whole lot longer, and be more durable, than powder-coat or paint.
Old Jul 18, 2006 | 12:35 PM
Car: 1986 Iroc
Engine: Afr 408
Yea, that seems like way too much effort. However, it would be curious to see what that effects along the lines of coolant temp or oil temp. Seeing as now you've reduced your surface area, but I don't know what a reflective surface like that would do. You would have to build two indentical engines to get a good comparison.
Old Jul 18, 2006 | 12:40 PM
Car: 1986 Iroc
Engine: Afr 408
I knew I had some more pictures of block prep. IF these pics show up, its a DEI cup block. I'd figure these guys know what polishing is useful and what is just for looks.
Attached Thumbnails Completly Polished Motor...Inside and Out-nextel-cup-block5.jpg   Completly Polished Motor...Inside and Out-nextel-cup-block6.jpg   Completly Polished Motor...Inside and Out-nextel-cup-block3.jpg
Old Jul 18, 2006 | 12:42 PM
Car: 1986 Iroc
Engine: Afr 408
Sweet, they showed up! I rule!! Alright, here are the rest..
Attached Thumbnails Completly Polished Motor...Inside and Out-nextel-cup-block.jpg   Completly Polished Motor...Inside and Out-nextel-cup-block4.jpg   Completly Polished Motor...Inside and Out-nextel-cup-block7.jpg
Old Jul 18, 2006 | 12:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That block is shot peened.
Old Jul 18, 2006 | 01:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that would be like bead blasting, but with bigger beads? giving the visual appearance of being sanded sorta thing?
neato.
I like the bronze lifter bore liners. Epoxied screens in place.. Very cool.
Camaro RUS, here's a few more helpful block prep tips you may or may not be thinking about:
groove lifter bores (tool from comp to do this).
groove on the distributor to help oiling for the back of the cam
smooth any sharp edges on anything and everything. Give it a little radius if you can, or a chamfer. If it's a moving part, be careful about upsetting the balance. But the main bearing caps are fair game. MAKE SURE YOU COVER ALL BEARING SURFACES WHEN YOU GRIND. Cover it with masking/duct tape, you do not wanting grinding sand in there. Wash it out good too.
Old Jul 18, 2006 | 01:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Vaguely like bead blasting, but with metallic beads and much greater force. It's a stress-relieving treatment more than a cosmetic or cleaning process.
Old Jul 18, 2006 | 02:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
I have heard of it as a stress reliving technique, but it would give the same sort of visual appeal though eh?
Old Jul 18, 2006 | 02:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It flattens out the cast surface a bit so it has a slightly more specular finish. Occasionally it's done for appearance reasons, usually on sculpture or architectural elements.
Also, if you're going to be grinding and polishing for stress-relief, make sure you're doing it in the right direction.
Old Jul 19, 2006 | 04:34 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Whats the thing running at the bottom of the bores? Thats a stock block with the cylender walls trimed right?
Old Jul 19, 2006 | 11:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Looks like part of an oil scavenging system.
Old Jul 19, 2006 | 11:44 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
no, that's not a factory block. it's a DEI Cup block.
Old Jul 19, 2006 | 01:39 PM
thesoundandthef's Avatar
Can't be all that bad, seeing the finish on CNC'd billet blocks.
I'm the guy who owns the polished 400.
Old Jul 19, 2006 | 01:52 PM
Here's a few more pics:
Old Jul 19, 2006 | 02:09 PM
Car: 1986 Iroc
Engine: Afr 408
Man, that thing is crazy. How long did it take you to do that? What combo/power are you going to build?
It does look sweet though.
Old Jul 19, 2006 | 02:39 PM
Approximately 200 hours...over a 2 year timespan.
I'm still debating that. Option 1 would be to use the 3.25 stroke billet Winberg crank I've got and build a quick revving 355 out of it, Option 2 would be to build a 427. What's holding me up from doing the 427 is the longevity factor.
What gave me the idea for the 355 was this article:
Small Block Chevy Should Have Built
Guys on Camaroz28.com are making pretty decent power with 355's under 7,000rpm, (450-475), so that'll probably be the way I end up going unless I hear a very convincing argument for option 2.
Appreciate the compliment.
Old Jul 19, 2006 | 08:35 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
damn... that looks nice
Old Jul 19, 2006 | 09:10 PM
Phatfiddler's Avatar
Actually, a member on here already built the engine you are referring to in the article. I cant remember his name at the moment, but he had excellent results.
EDIT: His name here is Wesilva. Might wanna PM him on his results.
Old Jul 20, 2006 | 11:38 AM
Thanks for the heads up. Will do.
Old Jul 20, 2006 | 12:42 PM
mw66nova's Avatar
Engine: 7.0L
B4CTom also has a 352, though he's either going centrifugal supercharger or twin turbo, can't remember which.
Old Jul 20, 2006 | 01:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
there are plenty of people who polish their ALUMINIUM engine block, but thats really the first iron block ive seen polished.. lol.
Old Jul 20, 2006 | 02:45 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I'm glad I brought this up. I've always wnated to see if anyone (especially the weekend mechanic) has polished a cast iron block themselves.
Very well done!
Old Nov 11, 2008 | 12:03 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Re: Completly Polished Motor...Inside and Out
TTT for thesoundandthef....still around? Ever built the thing?
Old Nov 18, 2008 | 08:43 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
We were corresponding for a while. I'll e-mail him and see what's up.
Old Nov 18, 2008 | 11:35 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"However, it would be curious to see what that effects along the lines of coolant temp or oil temp. Seeing as now you've reduced your surface area, but I don't know what a reflective surface like that would do."
That would be my first thoughts also. What effect does it have on the heating and cooling?
Old Nov 18, 2008 | 11:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There'd be no discernable difference in temperature.
Hotrodboba400
Dec 10, 2019 07:07 PM
Breazlan
Sep 25, 2015 11:20 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
