Piece of junk
Old Jul 21, 2006 | 09:19 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Piece of junk
Well after 3 weeks of messing with this helicoil garbage for my stripped out oil pan bolt, I got the helicoil to thread in some and when you put a bolt in it, it just spins with the bolt so not only is the helicoil stuck in there, but it helped none and made things worse. So now I am giving up and just sending the car to a shop to fix it so now the shop has to tow it and they have to fix it. Do you think $600 would be enough for them to fix this and reasemble it?
Old Jul 21, 2006 | 09:40 AM
Vader's Avatar
Is this a damaged hole for the oil pan mounting (on the rail of the block) or a damaged drain plug hole?
Old Jul 21, 2006 | 09:42 AM
Engine: LB9, LB9
rear driver side mounting bolt.
Old Jul 22, 2006 | 06:18 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Well, don't blame the Heli-coil, they work great if PROPERLY installed.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
tcarlos13
Sep 28, 2015 06:31 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
