what kinda numbers will this put out?
Car: 25th anniv. camaro
Engine: 305 tbi
78 350 4 bolt main..... 305 heads from a 78 with 1.6 rockers,bored 30 over,rpm intake,750 double pumper,488/510 cam.headers,flowmaster 80 series..flat top pistons.should be around 11 to 1 compression....
Car: 1983 G20 Chevy
Transmission: 4L60
300HP @ 4,500 and 330 TQ @ 3,500. Wrong cam (performer RPM cam is weak), stock 305 heads lack flow, 750 carb is too large for the rest of the combination.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what size valves, any porting ?
they flow fine til you hit higher RPM- in stock form
but everyone knows that
i have had the same engine and heads together in a 3800lb vehicle with 3.73 axle before, its great off the line and for a while but top end isnt much
but then the 4416 heads just had 1.94 put in them and were milled some and not ported or anything
good luck
good luck
1992 Trans Am
May 10, 2023 07:19 PM
