305 H/O vs 305
Car: 1988iroc
Engine: 350tpi
305 H/O vs 305
ok, so im new at all this camaro stuff (been into the 5.0 stangs) so bear w. me. my question is, whats the differance in the 305, and the 305 ho.? how can i tell which a motor is? can you convert a non h.o. into an h.o? and can you use the same parts/mods on each? thanks alot for all your guys help.
o btw... its in an 83 z28
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
in my 85 the ho meant better heads, cam, and higher comp ratio, and i believe different jetting in the carb
i think the earlier ones were about the same differences
Car: 1983 G20 Chevy
Transmission: 4L60
Transmission: 4L80E/4L80E
There is a thread on the FAQ forum about this very topic.
For the record, the heads were the same between an LG4 and the HO L69. Compression was lower in the LG4 until 1985 because of dished pistons.
Go look on the FAQ forum for the rest of the details.
