Car cranks, shoots fireballs out the carb
Old Jul 22, 2006 | 10:24 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Ok I just added headers, and redid the valvelash (turn push rod till resistance + 1/2 turn, flat tappet hydro cam) put in new plugs/wires and now it wont start. Set up thats in the sig.
I checked the plugs, and they were wet, so I double checked the fireing order 4 times, took the cap off, put it to TDC compression stroke on #1, put it too the floor, and cranked it again, and it spuddered out the exhaust, and shot a tower of fire out of the carb at the same time. If I leave it on the floor, and crank, stop, crank, it wont do the fire thing. I hooked up the timing light and while cranking set the base timing to 0, then 6, then 12, same results. I changed plugs again, and they are staying dry so long as I have it on the floor while cranking. The choke is also tied open.
What should I do next? I did try a little bit of starting fluid, but it didnt seem to notice at all. The car ran before it went down 2 weeks ago for headers. I also checked to make sure the balancer hadent sliped, and its just fine.
Old Jul 22, 2006 | 10:39 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I am not so sure that the headers are as much of your problem.... I think it lies in your valve adjustment maybe. Couple of questions for you..... Did you have the engine running when adjusting the valves? if not then just setting each pushrod 1/2 turn is not going to have them properly adjusted unless you brought each set of valves up and closed all of the way. They acually have a certain sequence for adjusting them all. I forget it maybe I can dig around and find it. I would check the valves out and then double check your ignition timing. Hope you find out whats wrong soon!
Car: 87 Firebird
Engine: 5.3 76mm
Oh and the ignition is a full MSD HEI set up.
I did it by the book, or the one that I have anyways. Witch was bring it to TDC and adjust what ever ones where at rest. I also re did it and did the open/closing method, where you adjust one, as the other is closing. If I could get it start, I would gladdly take the oil spray to properly set them.
Last edited by MaxxMitchell; Jul 22, 2006 at 10:40 AM. Reason: Automerged Doublepost
Old Jul 22, 2006 | 10:42 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
sounds like your valve lash is too tight..
Old Jul 22, 2006 | 10:44 AM
Car: 87 Firebird
Engine: 5.3 76mm
I checked compression on 3 of the cylenders while I was chaning plugs, and they all came out to 118-125. Guess I could go out there and check them again. Before the headers where on, and the car ran great, I checked it on 2 of them and had the same results.
Old Jul 22, 2006 | 10:46 AM
89RsPower!'s Avatar
try backing them all off 1/4th of a turn at a time then try to start it.. than readjust.
Old Jul 22, 2006 | 11:31 AM
Car: 87 Firebird
Engine: 5.3 76mm
Well I backed them off and it didnt seem to change. They are backed off pretty far now, I can jiggle the pushrod up and down.
I closed the choke and tried it a couple more times, and it back fires pretty constantly out the exhaust. Enough that It cought some paper towls on fire that were soaking up some oil. I just changed the oil as well, as it was thiner than I liked and reeked of gas.
Im going to start all over again on the valve lash, set it to zero lash, and crank, then start going in 1/8th at a time.
Old Jul 22, 2006 | 11:51 AM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
i'm leaning towards your wires are 180 out or in the wrong direction, (clockwise/counterclockwise) remember #1 tdc will have the rotor pointing towards the front of the car and crank the car with the rotor cap off to see which direction the rotor turns.
Old Jul 22, 2006 | 12:30 PM
Car: 87 Firebird
Engine: 5.3 76mm
U guessed it
Just fliped it around and it fired right up.
HOLLY wow what a smoke show!! These headers are going nuts with smoke right now
Old Jul 22, 2006 | 11:42 PM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
U guessed it
I was wondering while reading this when someone was going to say 180 off.
That will make a fireball everytime.
Old Jul 22, 2006 | 11:57 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Congrats on getting it. The headers will smoke alot till all of the paint burns off.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
