Block filler
Old Jul 23, 2006 | 01:56 PM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
Block filler
When you use block filler is it necessary to have the block re-bored afterwards (does the filler warp the cylinders when it sets)?
Old Jul 23, 2006 | 02:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Normally the block is filled before any machining is done. I don't know if it would distort the bores all that much, but it would be easy enough to check with a bore gauge. If it did, it probably wouldn't be anything that honing couldn't fix.
Old Jul 23, 2006 | 02:41 PM
Casey Butt's Avatar
Personally, I'd "guess" that if the filler expanded when it set it should simply expand a little into the unfilled area ...but it never hurts to check. It's conceivable that the top layer of filler could set first and cause the lower layer to distort when it sets afterwards. Anyone have any experience with Hard Blok?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
