hvac fan causes engine to stumble
Old Jul 23, 2006 | 06:26 PM
'89 Iroc's Avatar
Recently when i turn my fan on high my engine will start missing but it only does it on high. any ideas?
Old Jul 23, 2006 | 09:43 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
ECM is programmed to increase the fuel supply to compensated for the extra load from the A/C (also seen as a voltage drop.)
ANy thing that depends on the voltage being 12v, or regulated 5v will be affected although the ECM tries to compensate, might test your battery and alternator even if they're fairly new.
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Sep 17, 2020 08:26 AM
Casey Meyers
Mar 2, 2016 10:46 AM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
