Camshaft Selection Etc...
Old Jul 24, 2006 | 10:25 AM
CodyZ28's Avatar
Car: 84' Z28 Camaro
Engine: 355ci small block
Transmission: currently shopping for one
Axle/Gears: 3.08 posi
I have a 2 bolt main 350 bored 30 over, flat top pistons, stock crank balanced & cut, stock rods, older heads milled etc..., a holly 750 dbl pumper, victor jr. intake, headers are on the way, It will be going in my 84' Z28
up untill now I have been flying by the seat of my pants more or less, getting a part here & there. Now about all I lack is the camshaft, the fella at the machine shop where I had the block work done said anything with over a 500 lift would work, does that sound right? Does anyone run a similar setup?
Also I have a muncie M21 4 speed transmission, (however 1st gear is stripped) & a Turbo 350 automatic, do you all think it would be worth the $ (performance wise) to have the muncie rebuilt or just throw the T350 in?
Any help would be appreciated
SORRY just realized I posted this on the wrong page
Old Jul 24, 2006 | 10:39 AM
CodyZ28's Avatar
Car: 84' Z28 Camaro
Sorry I posted this on the wrong page
Old Jul 24, 2006 | 06:52 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
No problem, it can be moved
Old Jul 24, 2006 | 07:32 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What are you trying to achieve with the build? daily driver. weekend cruiser/racer? what heads? (casting number) have the heads been modified to accept higher than stock valve lift? (springs) studs, guide boss clearance height.?
If you go with the th350 will you be using the stock torque converter 12"(2200stall) or buying a high stall 10 or 11"?
Will you be staying with the 3.08's or??? Do you want a rough idle? /smooth idle?? do you want fuel efficientcy. (back and forth to work) or "take no prisoners" drag race power?
Linson
Oct 24, 2025 02:00 PM
mattcanty
Oct 12, 2015 11:08 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
luvofjah
Sep 26, 2015 08:28 PM
gta892000
Sep 16, 2015 12:40 AM
