Can I aftermarket Cam affect the TACH reading?
Old Jul 25, 2006 | 04:49 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Well, pretty easy question. I swapped an L03 for a Modified L98 setup. The cam is not huge but noticable by far. Can an aftermarket bump stick affect the Tach reading mine jumps a little after my swap.
-New Distributor, Alternator, Battery, everything, etc.
Old Jul 26, 2006 | 01:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No. It's a signal direct from the distributor/coil.
Old Jul 26, 2006 | 05:10 PM
techno101's Avatar
Car: 1989 Camaro RS
I used the coil from my L03, do you think it would be causing the tach to jump up? Are the coils that much different other than fastening brackets? Should I start with the coil then because my distributor is brand new?
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
gta90
Sep 15, 2015 04:00 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
