question about proflow air cleaner
Old Jul 26, 2006 | 06:26 PM
ReidK's Avatar
Car: 1988 Firebird Formula t-tops
Engine: 350 60 over...400 HP
Transmission: 700 r4 transgo shift kit
Axle/Gears: stock...373?
I have a 1988 formula and I just put a performer rpm intake on and I can't use my original hood anymore. I found an air cleaner that will clear under the hood. but my brother told me they are bad for your car and don't filter well. I was wondering what some of you thought. Here it is at this link: JEGS High Performance - Edelbrock Pro-Flo Air Cleaner
Old Jul 26, 2006 | 07:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A popular name for those things is "The Triangle of Death".
Old Jul 26, 2006 | 07:11 PM
That might be the only air filter in existence that's worse than no air filter at all. That is, is can do more damage, than good.
You'll understand after you've tried to clean burning molten foam out of your carb; or get that screen material out of being wrapped around an intake valve.
The foam is flammable. Yes, that's what I meant: it catches fire. How stooopid can it get.
That's not a go-fast, or even a dependable daily-driver, kind of part, AT ALL. It's a street-rodder type of part, for entering in those "square feet of chrome" contests that those guys have. You know what I'm talking about; you see some old car with a cool paint job and all that, then you walk up to it and discover that underneath the 2 chrome-plated dominators and chromed 6-71 blower and bug catcher and tall valve covers, there's a 1982 Caprice 305 long block. STOCK. Then when they crank it up, it doesn't have enough power to pull itself up onto the trailer.
Don't waste your money.
Look up F-bird 88's posts on the subject, he puts up the part # every now and then for the old factory "drop base" air cleaner they used on big blocks in camaros in the late 60s. It'll fit if anything will, and it supports a REAL air filter.
Old Jul 26, 2006 | 07:23 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
My buddy ran one on his 289 and tried to convince me it was the best thing since sliced bread, and "flowed awesome"...
Old Jul 26, 2006 | 08:26 PM
ReidK's Avatar
my brother (berlinettakid) told me all that same stuff. thought he was joking just wanted a second opinion, thanks
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
