string trick for belt size
Old Jul 28, 2006 | 02:03 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
How can you get a measurement from a string after you put on pulleys, if there is no belt and the tensioner is fully depressed? Wouldnt this mean that the size would be thrown off because there we be no tension on a belt of that size?
Old Jul 29, 2006 | 09:00 AM
Engine: LB9, LB9
So if I measure with no belt on and the tensioner depressed, then the belt should be fine?
Galaxie500XL
Feb 1, 2020 04:53 AM
iroczguy86
Sep 13, 2015 02:22 PM
m00n420
Sep 11, 2015 02:39 PM
MORREALE5
Sep 10, 2015 08:58 AM
FormulasOnly
Sep 6, 2015 10:42 AM
