My car breaks up at higher RPMs
Old Jul 29, 2006 | 12:06 PM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
I got a 350 with a 650 carb a 465/488 lift on the car. I got the car timed at 13 degrees. Once I get around 3,000 it starts to break up. I got the gap on my spark plugs set at .35 is that too big? or is my problem somewhere else.
Also just wonder if anyone else has this set up...I got a 350 with 9.5:1 pistons, but on top of them I got them on 305 heads...what does that put on my compression ratio up too....?
Old Jul 29, 2006 | 02:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you don't have enough info to calculate your CR. I have a 350 with flat tops and 305 heads though.
.035" gap sounds ok. What distributor do you have? What timing does it show at 3000RPM with no vacuum advance hooked up? (if equipped with vacuum advance...)
could be a bad ignition module, excess play in the distributor shaft, or fuel related.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
hokis
Aug 9, 2015 03:57 PM
