Sensor on Driver's Side head
Old Jul 30, 2006 | 03:50 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
What sensor is this? Knock sensor, water temp sensor?
I am about to put my new heads on, but there are no holes drilled for this sensor
Old Jul 30, 2006 | 03:59 PM
unklechuckles19's Avatar
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
I believe thats the water temature sending unit that goes to the temp. gauge in the dash.
Old Jul 30, 2006 | 04:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Water temp for the guage is on the drivers side head, fan switch is on the pass side head, and the knock sensor is in the coolant drain hole in the block, right near the starter.
If theres no spot for that in the head, then you can put that one in one of the holes in the intake manifold.
Old Jul 30, 2006 | 08:44 PM
Such as where? I just want to make sure I am rigging this right.
Old Jul 30, 2006 | 09:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
thermostat housing for example
Old Jul 30, 2006 | 11:58 PM
Air_Adam's Avatar
No, I wouldn't suggest putting it there, because then it won't read the engine temp before the thermostat opens. What happens if the thermostat sticks? The engine will burn up and you'd never know.
Most aftermarket intake manifolds will have a few spots to put your heater hose fittings on the front coolant passage where the thermostat housing is cast. One on the passenger side, and one on the drivers side. You should put your heater hose fitting (or a plug if not using the heater) on the passenger side, and the temp sensor in the hole on the drivers side.
This pic shows both holes on the front of the intake, on either side of the thermostat housing location:
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
