stock 083 heads with 2.02/1.6 valves?
Old Jul 31, 2006 | 01:52 PM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
I have the factory 083 heads with a simple gasket matching on the intake side. Will upgrading the valves to 2.02/1.6 make any noticable difference. I don't have any porting experience and I don't want to ruin the so that's wht only a gasket matching was performed. So, will the larger valves alone help??
Old Jul 31, 2006 | 03:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The greatest gains are realized by cleaning up the bowl area (the port right under the valve) and short side radius. Gasket matching doesn't help nearly as much.
Unless the bowl and short side radius are cleaned up, larger valves aren't going the help much at all.
Old Jul 31, 2006 | 10:14 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Get an old head to practice on. It's not that hard.
Old Aug 4, 2006 | 10:00 AM
Car: 1991 GTA
But what if only the valves were changed? Will I see a difference? How much extra cfm would the heads improve? I will try porting but I have to finnd an extra set of heads first. THanks!
Old Aug 4, 2006 | 10:31 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
only putting in the big valves would probably hurt flow actually.
Old Aug 5, 2006 | 10:51 PM
Car: 1991 GTA
How's that possible?
Old Aug 5, 2006 | 11:42 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
If you just cut for the valves you will create alot of shrouding and you will have a very noticeable ridge going into the ports that will create alot of turbulance when they cut for the larger valves.
Old Aug 6, 2006 | 11:13 AM
Sonix's Avatar
Car: 1982 Trans-Am
'zactly.
Picture a 1.94" valve getting 100% of flow around the circumference. Then put in a larger valve, now it's "closed" on the side of the wall, so you get a larger circumference, but 40% is blocked by the wall = net loss.
That's an exaggeration, but that's how it can work.
I wouldn't be too caught up in valve size, that's what the folks used to brag about in the '60s with old "double hump" heads and whatnot. Now it's more about the bowl area, and the angles on the back of the valves. Back cut, radius/chamfer front face, etc.
Old Aug 6, 2006 | 11:49 AM
shaggy56's Avatar
Car: 71 Nova
I agree the stock valve size can be made to be very efficient with some cleaup work. Look at this thread and you can see how far he got with the stock valve diameter. Check out his flow numbers in part 3 since those have the stock valves with the 3 angle valve job. He doesnt even cut for larger valves til part 4 and states this requires alot more work.
Here is a comparison between the 1.94 valves and the 2.02. He even states by working on the short side radius he could have gained even more flow to get it up to 100%.
1.94 1.5 valves flow
.1 63.8 41.4
.2 120.6 88.2
.3 178.9 124.1
.4 215.2 154.3
.5 240.1 171.8
.6 241 180
2.02 1.6 valves
1 72.4 47.6
.2 135.1 101.0
.3 201.3 140.2
.4 237.8 171.1
.5 264.6 187.6
.6 266.1 192.6
https://www.thirdgen.org/forums/tpi/...d-project.html
Old Aug 6, 2006 | 12:08 PM
Car: 1991 GTA
I'll see if I can find an extra set and start grinding.
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
