62cc heads to 56cc heads
Old Aug 3, 2006 | 03:02 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
what will my compression be if i went from 62 iron stock heads to 56 aluminum trick flow heads? the engine is a stock internal 350 l98.
Old Aug 3, 2006 | 04:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock iron are advertised at 64cc. What yours are exactly could be 2-4cc either way.
56cc aluminum heads would put you right around 10:1, depending upon the head gasket you used. Should be fine with aluminum heads.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
