rocker arm studs
Old Aug 7, 2006 | 03:15 PM
racnboy87's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
rocker arm studs
How much lift can the stock pressed in rocker arm studs on 081 heads handle? Im putting the LT4 production cam in my engine (not the hot cam).
The specs are like .450 with 1.5's and .480 with 1.6's. Do i need to get screw-in studs for that cam?
thanks
Bryan
Old Aug 7, 2006 | 03:49 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
I'm inclined to say that you can get away without studding the rockers. As long as you're not spinning the motor up too tight and don't have monster springs in it I doubt you'll have problems. I heard once...don't 'member where...that above .500 you should go studs.
Luck!
Tyler
Old Aug 7, 2006 | 05:15 PM
ede's Avatar
ede
my limit is around .47 or so. you can drill the studs for a roll pin, but if i were doing that i'd just get rid of the pull out studs to start with.
Old Aug 7, 2006 | 11:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
it's more about spring pressure, but yea, .470" lift is a good # to throw out.
I'd do the roll pin thing. Get a mittfull of 3/32" roll pins, 1" long, and 3 or so 3/32" carbide drill bits, and some cutting oil. Or BACON GREASE!
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
