when buying main and rod bearings, how many do need
Transmission: A4
I need to order a new set of main and rod bearings and this may seem like a dumb question but how many do I need? The rod bearings are sold each and Im thinking that I would need 8 correct. Now the main bearing are sold in sets of 5, do I just need one set? why wouldnt summit just sell the rod bearing in a kit instaed of each.
Transmission: 4L80E/4L80E
Example from www.summitracing.com :
Speedpro Federal Mogul Federal Mogul CP-Series Rod Bearings, .010"-under:
FEM-2555CP10 - one rod's worth of bearings. $3.39 each.
FEM-8-2555CP-10 - one engine's worth of rod bearings. $23.69 set.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: when buying main and rod bearings, how many do need
Lots of choices too. My rods have a dowl pin to keep the bearing from spinning (aluminum rods). I also use a chamfered bearing because of the crankshaft design. My crank has been turned 10/10 so they're all undersized bearings.
Other than that I only buy Clevite 77 bearings.
I spun a main bearing last year. Had to get the crank repaired. The block needed a new bearing cap and had to be line honed again. All the bearings were contaminated. There was no indication of a failure except a gradual loss of power and oil pressure was dropping. Most of the bearing material was trapped in the lifter valley because of the screens I have covering the drainback holes.
I'm to the point now where every winter the engine comes out and gets new bearings and rings.
Originally posted by ede
stephen i'm suprised you run clevites. i gave up on them after buying a set for a BBC that were unusable. any more it's FM for gernal rebuilds and C&A for preformance applications.
Clevite = Crap.
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Is there any recommendations for a specific bearing on a moderate performance build? I'm planning on putting out around 420hp and eventully a 150 shot spinning to 6200. Stock sized crank but should I use Bi-Metal, full groove, chamfered etc???
Scat 9000 crank and Eagle 4340 H-Beams.
TIA
TIA
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Federal Mogul 4663M main bearings, 2555CP rod bearings, and 1235M cam bearings should do fine.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I used summit brand bearings, hard to beat the price there.
Mwnova thinks they are made by "King", and therefore that's a good thing....
I wrecked them all, and i'm buying new ones of them... (wrecked due to flat cam, so I can't blame the bearings, if anyone was going to mention that..)
Engine: 383 Carb
Transmission: 4L60
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
