Check engine light
Old Aug 7, 2006 | 04:04 PM
swerve's Avatar
Car: 87 z28
Transmission: 7004r
Check engine light
When I get on the gas my check engine light will come on but seems to run the same. If I drive normal it will not and will run fine. My wife said she was driving and when she stops at stop signs the car will die, I have not seen this problem. I put the car on the computer and they could not find a code. Any help thanks
I cant see why it would matter but it started after new transmission install, which runs great with a 2400-2800 stall converter.
I dont believe that if I was having trouble with the TC lockup that it would make the check engine light come on. Also I drove it today and left it in third and the light came on again.
I also disconnected the IAC valve while the car was running and it did not change the way the car was running. Thought it should.
Old Aug 8, 2006 | 11:13 AM
Vader's Avatar
Disconnecting the IAC should affect idle, especially on startup, and may affect decelleration.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
