lock out timing in a non-permanent way?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I have an accel HEI distributor and I want to try locking the timing out to see how it helps my idle quality, I don't want to weld on a brand new distributor to see if it cleans up the idle, so what are my choices? I know a MSD style distributor has a bushing which will lock it out, but I don't have that option on my accel. Would wrapping safety wire around the weights keep them from opening to try it out before welding it permanently locked out?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you can remove the springs
use a zip tie
or safety wire
or like a twist tie, temporarily. Not a lot of force on it.
I think F-bird'88 posted once how to get a zip tie on it, without interfereing.
good luck
use a zip tie
or safety wire
good luck
Car: 1984 Z28
search is down right now to find his post, so i guess I'll hit up a hardware store and try to find some safety wire then, unless you think a smaller zip tie would work somehow? I'm trying to imagine how to run the zip tie to not interfere with the bottom of the weights
Car: 1982 Trans-Am
Yea, he described it... the "lock" on the zip tie was below the plate IIRC. Get some FINE safety wire, <.033"
Car: 1984 Z28
found his old posts, but it mentions removing the springs, and weights completely while using the zip tie, but i can't picture in my mind where to wrap the zip tie around if all those pieces are removed...?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Zip tie the advance plate (for lack of better/ proper word, y'know, the piece that moves seperately from the shaft...) directly to the shaft.
Im not sure how your dizzy is set up inside but from memory i think the old gm hei would be easy to do.
Car: 1984 Z28
i zip tie'd the plate today after removing the weights and springs and center plate and then added 3 zip ties per side to take up the slack in the advance slot to lock it down. thanks again...
Car: 1984 Z28
dramatically cleaned up the idle. I wish I would have known to do this right away instead of trying to drill holes in the throttle plates, etc etc. Much crisper sounding.
Car: 1982 Trans-Am
does the motor crank over ok? starter retard?
did it clear up your original problem of poor cold start condition?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With the timing locked out, you now set the timing to total advance. Try 36*. Providing it can still crank over and start advanced that much.
Car: 1984 Z28
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Feb 2, 2016 11:43 PM
