v6 - v8 fuel pump the same?
Old Aug 9, 2006 | 04:19 PM
fenderbender's Avatar
Hey guys, I have an 88 305 that seems to have some fuel pump issues as it looks like the previous owner direct wired the pump to the fuse block, it ran for while and now I hear nothing from the pump when the ignition is on and the car will not start. I also have an 86 2.8 parts car and I was wondering if the pumps are same as well as the relays cause im assuming thats what caused the previous owners to direct wire this thing. anything else I should check for/know about on this issue? Thanks
Old Aug 11, 2006 | 02:17 AM
Firebat's Avatar
I'm 90% sure the pumps are the same, if they are for fuel injected cars. Call up your local parts store and ask them to make sure.
Old Dec 30, 2008 | 01:08 AM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
Re: v6 - v8 fuel pump the same?
the relays shold be the same but the pumps are not the same
Old Jan 1, 2009 | 01:50 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
From the factory the pumps were different for different inductions - TPI, TBI, SPFI. The aftermarket sometimes sold the same TPI pump for all of the applications - works fine that way, and an upgrade for TBI and SPFI. So, don't trust the local parts store for information about what's in a 2.8 car.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
