Weird Gas problem - maybe
Old Aug 10, 2006 | 05:49 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
the other day i noticed a severe drop throughout my power band and starting off from a dead stop, felt like starting in second gear. a day or two later, it got to the point that when i went below about 2500-ish rpm it felt like the car wasnt getting fuel (jerking, choking..). I changed the fuel filter and it all went away for a couple days. came back again yesterday, so i changed the filter again and it was completly clean. But right after, i got all my power back. But that only lasted like 1 hour.
so now im stumped. i figured it was stuff in my tank, but after seeing nothing in the second filter, im confused.
any ideas?
Old Aug 10, 2006 | 06:49 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It would probably be a good time to check your feed line fuel pressure. IIRC you should see 40+ psi for TPI (please correct me if I have that value wrong). Anything less and you have a dying fuel pump. You can rent a fuel pressure tester for free at your local autozone.
Old Aug 11, 2006 | 11:53 AM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
its somewhere around 42psi i think. But what would this prove?
I can tell already that the car isnt getting enough gas. But a drop in pressure could be a clogged pump/filter as well...
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
