160stat or Bad EGR causing code 32?
Old Aug 12, 2006 | 12:37 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
The car is sluggish off the line, eventhough it's hot and nasty, on cold start up it doesn't roast the tires like it should. The motor is freshly rebuilt and I installed a 160stat once I got it back to keep the motor cool in these hot nasty months. However, after I installed the 160stat, I keep throwing code 32's. The car is getting up to temp, but it still throws it. Code 32 has something to do with the EGR and not reaching closed loop. But the performance sucks all the time. Mid range power is fine, but bottom and top end aren't so great.
Just curious if you guys think the 160 is causing the bad performance and code 32, or if the EGR is bad causing the code and bad performance? I will do the stat this weekend, but I've searched and haven't found anything saying a 160stat will throw a #32.
Thanks for your imput.
Old Aug 13, 2006 | 08:24 AM
Vader's Avatar
The car is getting up to temp...
What temperature is the coolant reaching? If the CTS is not at a constant 176°F with factory programming, the EGR duty cycle and EVAP purge are not at 100%, and that may be the reason for the error code.
Old Aug 13, 2006 | 03:10 PM
Car: 1994 Trans Am
I guess I'm just referring to the gauge. I know it's not accurate, but it's usually 3/4 the way to 220 <-----make sense?
So you think it is the tstat. Will that cause the sluggish performance?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
