help ac vents
Old Aug 12, 2006 | 07:50 PM
mystarion2's Avatar
help ac vents
ok ive got alot of replys but not the answer i need i need to know when i turn on the ac.my vent on top the defrost vents work but the vents that face the seats and driver dont have air comming out of them is there a vacum line off or somthing under the dash loose please help thanks guys. p.s the air is cold all the fans work
Old Aug 12, 2006 | 10:33 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Is your car stock? Vacuum would be my bet, as the "switcher" is vacuum controlled. Any cam or timing mods to your engine?
Old Aug 13, 2006 | 03:29 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Timnig or camming your motor will not really effect it.. not sure what year your car is but in know that on all three of mine right above the power brake booster there is a little black blox with a vacuum line and then a hard plastic line. the vac line goes to a manifold vac, the hard plastic line goes into the car and connects to a hose on the back of the vent controls.. also.. there are 3 vacuum diaphrams. that actually open the doors (the control is just routing the vacuum) One of the diaphrams is on the passengerside of the car by the kickpanel... the other two are under the dash behind the center console near the firewall.. if any of the Diaphrams are crapped out that door will not work...so it will be closed.. Most common problem is that plastic line to the thing though.. if it breaks which it is likely to do.. then it will default to defrost.. as that is the default configuration, since it is a saftey thing. Hope that helped some
Old Aug 13, 2006 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Very common problem on our cars. You might consider a . The subject has been covered many times.
JamesC
Pac J
May 17, 2020 10:44 AM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
Fanatic1074
Oct 2, 2015 03:47 PM
shanelique22
Sep 24, 2015 06:30 PM
sleprock
Sep 24, 2015 04:33 PM
