Firing on 7 cylinders
Old Aug 13, 2006 | 11:39 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
My dad's old Impala has a GM Goodwrench crate engine that he bought new about 9 years ago. He's thinking about junking the car, so I'm planning to pull the engine and drop it in my Firebird instead of buying a new engine. The problem is, he drove the car for quite a long time with one of the spark plug wires loose, causing the engine to fire on 7 cylinders. He's hard of hearing so he never noticed it until someone told him about it. Well, my question is, how much damage can be done to the engine in this case? What would I have to do to make sure the engine will be ok?
Old Aug 13, 2006 | 12:27 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Well, for starters the cylinder that was not firing had alot of fuel soaking into the cylinder washing away the oil... if it was like this for an extended period of time then expect some huge wear on those cylinder walls. It also puts more stress on the other 7 pistons and rods...
Old Aug 14, 2006 | 12:54 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
If you can still start the motor, put a new wire, or fix the one on there, fire it up, and run it for a bit, see if it still misses. If everything sounds good, run a compression test on all of the cylenders. If they are with in 10% of eachother, then it should be good to go.
Old Aug 15, 2006 | 10:03 PM
fastsprtcupe_82's Avatar
Car: 1982 Camaro Sport Coupe V-8
Engine: 350 Small Block
Transmission: 350 Turbo
Axle/Gears: one wheel wonder
yeah it all depends how long and how hard he was driving the car on 7 because if he was cranking on it it could do some serious damage and get it running and see how it runs and check compression
FormulasOnly
Jul 23, 2018 08:47 AM
meeklay812
Oct 1, 2015 03:46 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
