engine timing advice
Old Aug 13, 2006 | 07:43 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
hello, i was wondering, i put 91 octane in my engine, and i have been told to change the engine timing to get better power, i was wondering is someone could explain how to do this in detail for me, i have red the books, but any advice woudl help. i am new at this mechanic stuff and i dont want to blow anything up
Old Aug 13, 2006 | 08:30 PM
Damon's Avatar
Above the heater box, under the hood, sticking out of the wiring loom is a single wire weatherpack connector. The wire running through it is tan with a black stripe. When you unplug it all computer-suppplied timing will be taken away. What is left is the "base" timing. On a stock TPI motor the base timing is supposed to be 6* BTDC, factory spec. Most motors can easily take about 4* more (10* BTDC) if you use decent fuel.
Unplug the timing wire, set base timing, plug the wire back in. Done.
theshackle
Mar 5, 2017 06:37 PM
dutch930
Sep 11, 2015 06:58 AM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
