v belt length
Old Aug 16, 2006 | 04:26 PM
ceub's Avatar
Car: 1986 Camaro
Transmission: wc t5
Axle/Gears: 9 bolt
v belt length
Does anyone know what the stock size v-belts for the alternator and power steering pump are?
CJ
Old Aug 16, 2006 | 04:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
25" and 50" are what im running...
Old Aug 17, 2006 | 06:04 PM
ceub's Avatar
Car: 1986 Camaro
Transmission: wc t5
Axle/Gears: 9 bolt
How did you route the alternator for 25". I thought it drove the water pump too? Could you tell me how you routed them both?
CJ
::EDIT::
I guess I should mention what I'm looking for...I pulled the pulleys/brackets off of an '83 z28, but the belts were already off when I got to them! I plan on only running the alternator, power steering pump, and of course the water pump.
Old Aug 21, 2006 | 02:11 PM
ceub's Avatar
Car: 1986 Camaro
Transmission: wc t5
Axle/Gears: 9 bolt
ttt
Old Aug 21, 2006 | 02:29 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the last three numbers of the belt part number is the length in inches, for example 490 at the end of the part number is 49.0"
and so on
alt-crank-WP
and PS pump-crank
is how it goes
different lengths sometimes for different years/styles of p/s pump setups,
have to be careful, GM was good about using different bracket setups over the years/decades
the following is looked up for an 86 camaro 2.8L at napa:
Shop NAPAonline
Search Results
Genuine NAPA Parts.
Just a click away.
Browse Catalog >> Belts & Hoses >> Belts
Vehicle: 1986 >> Chevrolet >> Camaro >> 2.8 L 173 CID V6
Product Name Item # Price Select
Belt - Water Pump & Alternator
PBH
4040490 $11.29
w/o Air Pump
NBH
25040490 $19.79
w/o Air Pump
Belt - Water Pump & Power Steering
PBH
4017470 $4.29
w/o Air Conditioning
PBH
4017453 $4.29
w/ Air Conditioning
NBH
257460 $11.99
w/ Air Conditioning
NBH
257470 $12.39
Belt - Water Pump, A/C & Power Steering
PBH
4017550 $4.29
NBH
257550 $13.89
Belt - Water Pump, Alternator & Air Pump
NBH
25040525 $21.29
Old Aug 21, 2006 | 04:07 PM
ceub's Avatar
Car: 1986 Camaro
Transmission: wc t5
Axle/Gears: 9 bolt
Thanks for the info! The pullies/brackets I pulled off the '83 are going onto the 350 that I'm putting into my car. I'm also using the alternator (not sure of amps) and power steering pump that came on the '83. The car will not have an air pump or ac.
I think I read somewhere else on here to use 44.5" belts for both, but then again I'm not sure. If I bolt it all to the engine I can use a rope or something to get the length right?
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
