Oil control during hard braking need advice !
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
I am going to rebuild my 1989 L98 so i need advice for the oil pan setup to handle oil during braking what pan should i get or is there anything i can do to the original pan setup.
I have a windage tray already that i will install during rebuild will that be enough or can i do more to correct this problem !?
If someone have any specific part number for a good aftermarket oil pan(Milodon/Moroso etc)it would be nice and other parts to match.
The car is used sometimes on roadcourses and short sprint tracks and oil pressure dips dangerously low offcourse during hard braking.
Thx Mats
Thx Mats
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Moroso 20172
Moroso : Category Display
A better alternative to keeping oil pressure up during racing is to install an oil accumulator. I use a 23900
Car: '89 Firebird Formula
Engine: 305 TBI
<stupid questions>
is it difficult to add one of those on an otherwise stock setup?
and do you end up with more oil capacity? or do you stick with the same and just end up with alot less in the pan most of the time??
</stupid questions>
</stupid questions>
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you want to add how ever much the accumulator holds, say it takes 5 quarts for an oil change & you have a 2 quart accumulator, you put in 7 quarts.
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
