Tranny cross-support bolt size.
Old Aug 21, 2006 | 01:45 PM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
91 vert, 5 speed, The bolt that connects the tranny support to the frame is stripped. I cannot figure the size, although I could remove the other and take it to the hardware store. However, I was hoping someone would know it.
Old Aug 21, 2006 | 01:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
M8 coarse, x30mm or so.
These strip pretty commonly, lots of different ways to fix it. I tried drilling and tapping it to 7/16" but didn't get enough thread strength out of that "hard as cheese" insert in the frame.
I dropped a socket capscrew in from above.
Search in the trans-driveline forum about tranny cross member bolts or something, that should help you out.
Old Aug 21, 2006 | 01:58 PM
I think actually, they are M10 (15mm head).
Old Aug 21, 2006 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, good chance you're right on that. Mine had 3/8" NC, not sure if that was stock for my year, or what the previous-goofball put in there...
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
