egr selinoid
Old Aug 21, 2006 | 07:07 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
egr selinoid
does anybody know what this is used for? egr selinoid on back of intake? do i need it for anything or can she go?
Old Aug 21, 2006 | 10:13 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
its driveable with out it.
but you will get a check engine light. the EGR valve solenoid is what the computer uses to the control the EGR valve.
the EGR system is for emissions & can also help to increase fuel mileage.
Old Aug 21, 2006 | 10:36 PM
Engine: 355
so should i keep it on or go ahead and take off?
Old Aug 21, 2006 | 10:39 PM
DENN_SHAH's Avatar
i recommend keeping it & if it doesn't work, to fix it
Old Aug 21, 2006 | 10:40 PM
Engine: 355
o ok im tryin to make my car get more horsepower just tryin to eliminate stuff worthless or dont need. thanks though
Old Aug 21, 2006 | 10:41 PM
Engine: 355
o ok im just tryin to get more horsepower and eliminate worthlesss or dont need items. thanks though
Old Aug 21, 2006 | 10:43 PM
Engine: 355
o ok im just trying to get more horsepower and eliminate things worthless or what i dont need. thanks though
Old Aug 21, 2006 | 10:48 PM
Engine: 355
also is an 84 camaro 305 carberated an lg4 or what do they call it?
Old Aug 27, 2006 | 08:06 PM
Jays92Camaro's Avatar
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
DENN - In trying to trouble shoot my Code 32 issue...the good book says to apply 10mgs to the manifold side of the solenoid...I am unable to verify which port that is...it may not have been installed correctly. Is it the port with the metal reducer or the wide open one? Again the manual just assumes you know which is which.
Thanks,
Old Aug 28, 2006 | 08:00 PM
DENN_SHAH's Avatar
billybob6110, a properly working EGR valve doesn't add or cost any power.
if it is working right the only time it is open is under cruise or light to medium acceleration.
Jays92Camaro, im not sure, but i think the port that is metal is the vent port.
you may want to go the the parts house & look at a new solenoid, if the new one has a piece of foam on it, that will be the vent port. when the solenoid isn't turned on the port that goes to the EGR valve is open to the vent port
& the vacuum port is closed.
also, the solenoid can check good, but still be bad. it may not open once it get hot or may stick open when hot. thats why i always recommend replacing them when i put on a new EGR valve.
to check the valve to see if it is a back pressure type of valve, put a piece of vacuum hose on it & suck on the hose, if it opens then that valve isn't a pressure type valve.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
